Focus cam belt has let go :(
28 Jan 2005
Southport
Hi all,
Was just pulling out of work this afternoon and the car lost power. Tried to start it twice and it didn't sound good so I opened the bonnet. Had a look at the cam belt and it was loose :(
Looks like the tensioner has failed. The local garage towed it in and said they would ring me and let me know. They rang and said they put a belt on it and the compression test came back fine, all 4 cylinders blowing 150 i think he said, they then put the leads back on and it was missing on cylinders 2 and 4 :( He reckons the valves will probably be bent but hes going to take the head of tomorrow and have a look then let me know what its going to cost :(
Its a Focus 1.8 done just under 69k. What do you think this is going to end up costing and is it likely just the valves that are goosed?
Unlucky :(
Waste of time messing about with that engine, source an engine from ebay and have a local indy fit it for you. The engine will be around £300, as for labour it depends.
It cannot have passed a compression test AND have bent valves.
One or the other is wrong...
When it comes to that sort of thing i dont have a clue. Im sure thats what he told me, im stressed to hell at the minute, in the process of buying a house so this has come at a bad time to say the least.
IIRC the change interval on these is 100k? (or was it 80k) still, both are more than your mileage, but it is getting on for the right age for changing the belt.
As above, if the valves are bent (usual consequence of a snapped belt or failed tensioner letting teh belt jump) then they are jammed open and the compression test would show low on the affected cylinders.
Running a compression test basically means removing the spark plugs, replacing them with a pressure monitor and turning the engine over and getting a reading.
If the valves were shot, the engine wouldn't hold any pressure and that would be really, really obvious to the person running the test.
I know I've massively simplified that but in essence from that you can see that he cannot say that the compression test results are all good and then telling you that it is running rough because the valves are knackered!
For what its worth, it is very very likely that the valves are toast and he just got the compression test results wrong somehow. It would have been a miracle to avoid valve/piston contact at the best of times on an interference engine, but you subsequently trying to start it a couple of times means almost certain death for some of the valves.
Yea its been tried numerous times. They warrant the "belt" for 100k that is all. If it snaps before 100k then fine but they do not warrant the tensioners. :(
dYeh there 10 years or 100k miles. I don't know how Ford can get away with it!
This worries me as mine is on 68k at the moment. I'm looking into getting mine changed ASAP.
From what i've seen the belt seems to be fine after 100k but everything else that runs off it is a different story!!
From what i've seen the belt seems to be fine after 100k but everything else that runs off it is a ifferent story!!
Get it done mate, i was like "o it will be ok people have done 100k with no problems" Im ment to be going away on monday and was going to get it done when I get back. It will save you a lot as I will no doubt learn tomorrow :o
They have had plenty of practice with other engines, e.g. the old 1.8 diesel that used to snap belts for a pass-time. 100k/10years is exceptionally good for a timing belt, have to wonder if that was driven by fleet requirements or actual reliability testing
