- 15 Mar 2010
- Bucks
v.cool!!
BUILD LOG LINK IN SIG![]()
Can you please tell me what water cooling componants you are using, & post a clearer picture of the layout of the reservoir pump etc.
Many thanks.
Meh, I must be the only person nowadays trying to overclock on air. I got red fans in preperation for the Rampage III Extreme:
Had the window on the Fortress FT02 fitted on the inside with some socket head caps.
Got 3 windows made up with it as well so i can swap them over - clear, black tint, and frosted.
Lol that case must be like a light show with those fans, although they look more pink than red in those pics. I'm looking to get some good blue fans for my pc, what are a good make?I know, I forgot to add the
These coolermaster LED fans are awesomely silent, you can just stick your case full of them and they are still inaudible.
I just have 8 blue ones left over to get rid of (had 3 thermaltakes from my previous case, and 5 coolermasters in the current one).
The Prolimatech MK-13s are triple slot and expensive though, but they should work on all future graphics cards as well. Finding a new mobo to accomodate them with a soundcard in the future will be hard, but it will actually dissuade me from buying new motherboards until the next capable one is out (I want 2x 16x PCI-E with triple slot spacing, and space for a soundcard).
The difficult part will be trying to get rid of my collection of 2 Thermaltake S Orbs, and 2 Zalman VF950s. Those are difficult to sell.
My PC7-FW:
It's a Q9550 system with a H50 cooler and crappy 8800 GTS 640. Got the rad and push/pull fans zip tied into the drive bay area with an additional Lian Li Fan bay and Akasa Apache inside it. Other fans are Enermax Clusters.
Yes is could be tidier and it is a little dusty despite the filters. I have a skin condition that means I'm alwas going to be against the dust anyway but I clean it the best I can. I'm hoping to get a 5870 at some point so will tidy some wires then methinks.
Hey, do you know how much room you would have with a 5870 in this case? thanks
where did you get the ATI stickers for the case ?
