- 13 Jul 2004
- Stanley Hotel, Colorado
Igrargpu is a utility that uses both cpu cores and gpu cores on cards upto the 5870 to break codes.
There is not a fancy graphics benchmark just pure numbers computer speed test
For this test just unrar to a directory and drag and drop the example encrypted rar onto the igrargpu.exe
The rar will give a password error, thats the whole point. You break the password code with brute processing power so just unrar everything but that passworded file and then drag and drop it onto Igrargpu to get your performance figure.
My result above is 3750 words per second with dual cores and a 4870 but Im sure someone can do better
Try to take a screenshot on a 5 letter word or higher to get an accurate result, shouldnt take long on any modern setup
http://rapidshare.com/files/371199338/_igrargpu_v05.zip.html
Description
This software using ATI RV 670/770/870 and nVidia "CUDA" video cards to recover passwords for RAR archives v 3.x. Recovery speed at HD4850 about 20 times better than single core of Q6600 @ 2.4Ghz. (Comparing only optimized SSE2 code running on iCore. Currently only 2 programs heavily optimized for RAR 3.x recovery -- crark & ARCHPR). For non-optimized CPU versions it can be [place your favorite number here, like 100x or 200x].
Performance on nVidia cards slower than with ATI ones (because of nVidia GPU architecture). So, 8600 GT about 2x times faster than single core of Q6600 @ 2.4Ghz. GTX 260 /w 192SP about 12 times faster than single core of Q6600 @ 2.4Ghz.
Plain numbers (for RAR passwords with length == 4) are:
~168 passwords per second on single core of Q6600 @ 2.4Ghz (crark's result)
~325 passwords per second on 8600 GT
~3350 passwords per second on ATI HD4850
~2075 passwords per second on GTX260/192SP
Note that password recovery speed is not constant for RAR archive, it depends on password length (i.e shorter passwords will be checked faster than longer ones.
only using 1 CPU core though
), and my system isn't as responsive as it could be. I've got an AVRSPD of about 3700 at the moment.
