Hmmmmmm ....
I wonder if this board would be able to handle my 12 Gb ram at 2133 Mhz =O
It probably still wont manage as the Memory Controller is on the CPU.
That new UD7 looks more akin to a EVGA 4x board with a horrible form factor. I like that the RoG boards at least fit in most decent mid-tower cases. Uses 2x NF200 aswell. Ugh! Still it looks good (red/black is getting old fast) and it seems to use MSI-like DrMOS vrms.
Helios1234, if you dont mind me asking what are the bios fan options like? Any chance of a screenshot? All the headers are 4-pin so it would be a shame to waste them.![]()
That's what I'm waiting for too. Spending £350 on a motherboard is bad enough but £900 on a CPU (i7-980X) is just crazy. The i7-930 will be perfect for the moment until the i7-970 comes out.The I7 970 should be released in Q3 at $500, so around the same price as this mobo. It should have a better multi at 3.2 ghz than the 920 or 930. This board was made for it.
Will there be an OCUK overclocked bundle with this board once it hit retail?
you can bet your bottom dollar
i will be working on a bundle the second i get a board to test.
FFS, I wish that I had some patience...
£329 seems like a reasonable price for a board like this, if only I held off buying the RIIE.![]()
. Ive taken my current board out 3 times to reseat the CPU heatsink though as something was very wrong with my temperatures. After I used MX3 with the quad core line method though my temps are several degrees better than both the H50 and Megahalems temps in reviews rather than being worse.
