- 10 Mar 2010
why does it lose 2marks?
i will take a look at it now
okay thanks then it should be fine, its around 1.1 going upto 1.17v so that should be okay
does this go up when gaming?
how do i make it so that all my fans go max all the time?
yes it'll go up under load..
turn off smart fan in bios
does the fans have heat sensors?Smart fan was turned off and yet the fans still dont go at full speed all the time
what else can i try, by the way the all the fans except the CPU fan are connected directly into the power if that makes any difference
it's different for different motherboardslooking more closely it seems TMPIN0 is the Motherboard while TMPIN1 is the CPU?
but on mine on Everest the Motherboard is 25c but on HWM TMPIN0 is 32c - how does that work? and why does yours stat CPU when on mine with Everest it doesnt
don't forget i have a different case and heatsink..how come the temps are so low, with just around 30mins or so on X3 Terran Conflict maxed out i hit 47c on TMPIN0 what is the difference between the 965be and the 955be?
i was running prime.so the TMPIN0 and 1 will be different for each motherboard, um didnt know that thanks.
why is yours 11c cooler then mine when yours is on FULL 100% each core load, mine hit 47c on the TMPIN0 while playing X3 Terran Conflict Max or should i be trying Prime and compare the 2 after that?
gaming won't max out the cpu.
could the case and heatsink cause that much of a temp difference?
i mean i have ALL fans going and everything so it shouldnt really be that should it?
what Fan do you have? isnt it that HUGE thing? that i am pretty sure wouldnt fit in my case. do you think 47c with 30mins of maxed out gaming on X3 Terran Conflict is a decent temp? am i worrying too much?
