Just ordered a gtx470
Status
Not open for further replies.
Your link would be irrelevant as your reply has no relevance to my question as your reply is not about a recent event.
Anyway i just thought that i may of missed a recent event & i only wanted to know about it.
There is no reason to get wound up.
ok. consider the matter dropped.
It did, but that didn't stop the 8800 series from getting better, too. I mean hell, AMD is still releasing drivers that increase the performance of the 4800 series almost two years on. In fact I believe I'm correct in saying that the 2900 series currently fares worse against the 8800 series than it did at any point during its life span (although I suspect that's mostly because testing with 4xMSAA is now considered standard).
Can't tell, I dont have an 8800 around to test with anymore :)
Either way, AA off, the 2900XT is definately faster than it used to be, which is why its trucking on fine in a family PC, as most of the people using it are more casual gamers so dont require heavy AA doses, and its more than capable for most stuff with the AA off.
Shame really, if TSMC hadn't botched it and forced it out on a higher nm than intended, with lower clocks, it probably would have been quite a nice card.
Listen people
GTX 470 beat a 5850 but costs the same/more than a 5870
GTX 480 beats a 5870 but costs almost as much as a 5970 and is not as good as a 5970.
Solved.
What do I win?
Listen people
Solved.
What do I win?
The issue is that they're faster in some, slower than others.
...and for some people the PhysX / CUDA / Tessilation / performance + 3D View is important. /shrug
The main reason I made the switch to nvidia was for physX with DX11 support mainly, I could've bought a cheap 240gts card for PhysX but I really could not be bothered to try and get it to work with ATI.
Not to mention that GTX 470 are priced £50 more than they should be (after $ conversion & VAT) within the UK. In the US they are closely priced to the 5850, but here they equal 5870.
£250 would make it a much fairer punt.
Listen people
Solved.
What do I win?
To be fair this does seem to be the case, if you are gonna get a 470 @ its current price you have to agree the 5870 is cheaper, atm by a few quid, and faster overall...
Listen people
Solved.
What do I win?
One minor fix, the 5850 will overclock past the speed the 480 can achieve, on the stock cooler quieter than a stock 470gtx, and neither the 470/480gtx will likely get close with overclocking.
1Ghz is achievable but seemingly rare and not with silence on a stock cooled 5850. 925 is very easy, thats over a 25% overclock, hit 975and you're at about 35% overclock, the few that can hit 1Ghz, will have a 40% overclock.
The few overclocking tests I've seen suggest maybe a 10% overclock, eek that out to 15% with voltage control IF there is voltage control, it won't come close.
Thats the big problem, the 5850 has HUGE headroom, I mean huge, and anything this generation but a 5850 is a daft buy, be that 5870, 5970(at current prices, at £430rrp its still a choice but frankly 2x 5850's would overclock better and be easier to cool), 470gtx, 480gtx, or a likely 460gtx.
The 5850 is the single most obvious choice between gpu's in the high end market, in the past decade frankly.
After the 4870 was released, the 260gtx 216 version came out and it was priced not far off a 4870, either would give you great performance at competitive prices, you'd not be dissappointed with either.
THis gen, theres nothing close in price/performance to the 5850 and unlike last gen, the 5850 can produce top end performance, where the 4850 could not replicate 4870 performance under any circumstances.
Although I think kylew trolling (kind of), I do agree with him on this. The 470 is just a non-starter compared to a 5850, a complete waste of time. If I was limited on budget then no question my choice would be a 5850 and overclock the nuts off it.
If NV is your weapon of choice, bite the bullet and get a 480.
I'm not really trolling, it's banter to me, some people take it too seriously.
One thing though is that I really can't understand why some one would spend £100 more just to get the brand that they prefer.
I mean, as much as I dislike nVidia, I know I'd be all over their cards if they were in ATi's position.
To me, the 5850 sets the bench mark for a level of performance compared to price.
Anything above that price for no more performance means to me, the card is pointless.
As it is, I think the 5870 and 5850 are quite overpriced already, but there's nothing that gives 5850 performance for the same price, so yeah, if ATi were £100+ more money for the same performance, I'd be all over an nVidia card.
I'm so glad I got my HIS 5850 for £198 with Dirt 2 which I would have payed seperately for £25, bargain!!! AND the only impulse purchase that has really paid off :p
Enjoy the card mate, should be a nice upgrade from the one you have atm
edit - Keep from posting inflamitory posts please. Doesn't take much to set them off. Jedi
I dont mind the banter, I can take all the banter on the chin. I like it here because of you do get solid advice !
Status
