- 19 Jan 2006
So you go ahead and stop playing every 22 minutes to spend 2 minutes changing a battery if you want, personally I would rather like to play for longer than that.
The most economical nitro engines will get you around 10 mins of run time per tank, your having to refuel twice before I need to change a pack. I can run literally non stop all day until my transmitter battery dies or I kill my trucks. Once one pack dies I whack it on the charger and it will be charged before the second pack runs out.
you are in no position to say which is faster.
Having run nitros in the past for many years with top end nitro engines I know for a fact that brushless is far faster, my truggy used to run a Ninja MR-1 engine which was one of the fastest nitro motors availible. My brushless setups will kill any nitro out there.
And there is no point in putting up a youtube clip of someone else as your are clearly saying that your's are faster than anyone else's even though you have no proof.
That said, you put up a couple of clips, so I will as well.
134mph.
This one is even faster.
Both of those video clips are using exactly the same brushless combinations I run so they are very comparable to my cars. The first video is of a brushless car, so what has that added to your arguement? The second vid is of a tether car, they are tethered to the post in the middle and just go round in circles, they are useless at anything other than top speed, there acceleration is diabolical too.
