Edit: woops it's MyWay not Nav N Go!
Wanted to share my thoughts on this as many are using nav apps on their phones, much more convenient than carrying an extra TomTom around etc.
Been using Mobile Maps 9 for a while now and have had 99% success rate with it, there was only one local road it got confused with but I think that was a one off thing. I've used it to get to interviews in perfect timing since then and it's been just great with precise and clear voice notes and junction/A/B road name speaking.- I rarely look at the map any more.
I wanted to compare it to iGo's Nav N Go for Android which I've been using for about a day now and I have to say both are much nicer to use than standalone satnavs I have used before (Navigon, TomTom OneXL, Garmin 255WT/200W).
The iGo has some sweet transition effects and I really like the way you can drill down to finest detail on planning a route, like when you start by entering the town it begins searching as you type and continues right through to the door number/post code and intersection entries. It also greys out numbers/letters in the entry screens that are not valid for the current entry (see screens below).
I'll be navigating my way home today at 4pm using iGo to see how it compares to Sygic Mobile maps 9 but I have to say it is impressive so far
Another awesome feature I found that I really like on the iGo is that when you've entered your route and it's calculated it all and showing you the screen with route information/distance etc you can choose to be shown the distance + ETA for the other navigation modes as well (FASTEST/SHORTEST/ECONOMICAL etc - I find this feature extremely helpful in deciding whether it will be worth taking the back roads or the motorway based on the ETA and mileage.
Official page: http://www.igomyway.com/android/en/screenshots.html
My only issue with it is because of the funky transition effects the UI is a bit slower to navigate than Sygic/Google Navigation (via modified Google Maps) and there doesn't appear to be any option to turn off transition effects. The keyboard also seems to be slightly slower too but not by much, key entries still register but on screen key presses don't show up for a few ms - I guess this is due to the software doing the in-line searches as you type in a destination.
Sygic is still my main navigator but 'll be sure to use this more as well.
Will update later this evening, unless I get lost going home and end up in Staines or something ¬_¬
