You can tell if the sensor is over heating without using an EGT gauge. "08- Sensor Timing Error". Which you can either see on an LM1, or you'd see on the diagnostic LED.
i've had my wideband lambda on one of my primaries, the reading fluctuated as it wasn't a reading of all the gas coming out of the engine. I've since moved it to just in front of the cat, the reading is nice and stable - with the averaged readings no different to how they were when the sensor was further up (they just don't swing about all over the show now!)
Where the sensor was, i have an EGT sensor now. Which when hooning about reads around 600c.
Granted I don't have a turbo. But I have fitted an LC1 and gauge to a heavily modified Rover 220 'tomcat' Coupe, and with that fitted in the stock OE placement (elbow) it worked fine with no timing errors (this is what the LC1 gives you if the sensor is out of its operating range). I then asked Grant from GB-Ent (who had supplied the head, turbo etc that were being used) and he suggested fitting it down stream a bit, just behind the sump.
An exhaust system is made of machined flat surfaces that are bolted together, with either a gasket or a tiny slither of paste. Not going to get into the debate regarding using paste upstream of the turbo as it doesn't matter. Both placements are downstream, and if you are introducing a leak going from the elbow to downpipe then you've got some issues with the exhaust.
,I'm a bit surprised you repaired the engine mount rather than replacing it, they can't be that much to buy a replacement?
