Infected php files.
1 Aug 2006
Not sure if anyone can help i may be right off track here but..
I have some php files which i think one or more are infected.
Any free dedicated php detection software on the net ? or am i totaly miss in formed and a normal checker do the job.
Also i need it repaired do i hand edit or... ?
Sorry for the lack of understanding.
PHP's have been attacked for a while now so I would expect any anti virus worth it's salt to able to detect and remove. You'll probably have to pay for a version to run on a server though.
Andi.
Just seen this.
If you have been infected with the "base64_decode" problem and have shell access to the server, I have a bash script here that will clean it up for you.
To add to the above I also found this cleaner from Succuri Security which will fix it from a PHP script (handy if you don't have SSH access). I had to manually clean this once (fortunately I had SSH), wish I'd found these scripts sooner however as I had to write my own :p.
Note: It won't work if the regex isn't right. One site I fixed I had to modify the regex to get it to work as the malware had changed its signature. Once I fixed that it chomped through hundreds of PHP files in a matter of seconds.
