I always used to cycle about 3 miles to work before I had a license... And half a mile to school every day.Hello
I've bought a new bike for commuting (Carerra Subway hybrid-style) and tomorrow I'll be cycling to work for the first time on it. Who else does this and how do you enjoy it compared to driving?
I didn't particularly enjoy it but I'm a lazy ****, it's not terrible and easily doable though, a tad annoying to cycle against the wind but meh, it's all easily doable. You will save money on fuel though of course and it might help you with your daily exersise.
Took me 15-20 minutes for 3 miles depending on how fast I cycled ( but I had quite a lot of traffic lights on the way). Could do it faster if you are in normal/good condition but that was the ONLY exercise I got, my fitness was ****.I'd also like to hear:
- How long should it take a reasonably fit male in his mid twenties to cycle 3.8 miles on a relatively flat cycle path?
I just used my normal clothes, I did not wear a helmet as that's not the habit here ( so can't comment on that), you aren't drenched in sweat, you might sweat a tiny little bit ( or well, in my case anyhow) but nothing a bit of deo in the arm pits can't take care of. Of course if you cycle more relaxedly you will barely sweat at all and even without deo you won't smell... It's quite easy, cycle calmly if you don't want too much sweat, cycle as if the cops chase you if you want sweat to drench you...- No showers at work, but there are at a gym three minutes from work. Is my best tactic to go in work clothes and hope I don't sweat / get drenched / get terrible helmet hair, go in light casuals and change at work, or cycle straight to the gym and shower there? By which I really mean, what do people that don't have showers at their workplace do to 'stay fresh'?
200 is relatively cheap, I'd spend 50 ish on a lock just to be sure, I have a bike worth 250€ new and used an expensive 70 € lock for the first 2 years, after that cheap locks and it never got nicked and bike nicking is very common here. Atm I use a 3€ lock which can probably be cut with regular scissors but my bike now looks quite worn and rusty in places so it doesn't really get nicked, nobody will bother for a bike probably worth only 20-40 on sale...- What lock should I buy? The bike is worth £200, is kept in a garage at night, and will be stored indoors on company premises during the day. Insurance covers against theft from home, if on actual property.
I'd use the max recommended pressure, it loses pressure anyhow and more pressure means easier to pedal/less resistance, it'll lose pressure over time anyhow, just re-inflate once it reaches about 40-45 back to 60 and ride like that, that's what I do, max recommended pressure at inflating, and inflate again once it goes below the recommended ( or well, I used to ride on it till it was so bloody soft that if you went off a curb the rim would hit the ground, but that was due to laziness and I wouldn't recommend it).- Recommended pressure for the tyres is 45 - 60 PSI...what end of this scale should I be inflating to for road commuting?
Can't help you with that I'm afraid, I just buy all my stuff for my bike at Halfords, it's a cheap mountain bike anyhow (mine).- Where's the best place to buy accessories like mobile repair kits, water bottles and holders, pumps, panniers, etc.? Specific links if internet please.
- What greases and oils should I buy to keep the chain and gears protected and where should they be applied?
Love you!
Something that does not stick to dirt, that is the most important, I used to spray my brake cable ( they were not moving smoothly) tubes with an oil that did and in the end a lot of dirt attached to the cable and it broke in the end.( a very thick layer of dirt mixed with oil attached to the brake cable when I took it out of the tubes it went in) Afaik WD40 does not make dirt stick to it ( somebody correct me if I'm wrong), but bike shops recommend something called ''kroon'' oil here which is actual oil not a spray, do not use generic silicone oil sprays though like I did...
