HD5970 4GB!
14 Sep 2009
Northumberland
I'm not sure if this has been mentioned, but hey :p
Even though I personally thought a HD5770 is good enough for gaming, and that a 5970 is over priced
and not really needed,they release a 4Gb version. Heres is some of the article from Tweaktown as they test
one of the four models made, and here are a few of their results.
From tweaktown.com
The GPU itself.
Some benchmarks.
  • [*]Farcry 2.
    [*]Battleforge.
    [*]3D Mark Score.
This card doe's look quite a beast, and wouldn't mind seeing what it doe's on Crysis, but I would still expect atleast
an £800 price tag.
The the full article if you want to see more :)
Those are some pretty unfair benches as well, as the 480 is a single GPU and the 5970 is a double. A fairer comparison would be 480 vs 295 vs 5870 vs 5970-4gb.
Couldn't understand why the memory was making such a diff at soem of those games/resolutions - until I looked on the article to see it is clocked at 900MHz, which is quite a bit higher than the 725 of the 2GB version.
the 5870 1 and 2gb dont make any difference even in triple eyefinity resolution (5760x1080 or so), so i dont see how is this making such difference either
Imaging 3 of them LOL 12 gig of video memory. You would never have to worry about video memory being an issue for a long time. 3 of them would see you through DX11.
1) The memory doesn't double or triple, I believe it's mirrored across all the GPU's.
2) AFAIK, gaming drivers don't support 6 GPU's, so that's a no go
3) You'd need a case with 9 PCI-E brackets and a motherboard with 3 PCI-E x16 spaced 3 slots apart, which doesn't exist, I don't think.
£600-£700, around $1000 for the special OC'ed 4 Gb models.
I'm dreaming of an Asus Ares to go with my R3E :(.
Ooooh, even an Asus Ares plus a ROG edition 2 Gb 5870, that would be soooooooo sweeeeeet to play with :( :( :( :( :( :( :( :( :(.
