Saying it was created by God does exactly the same thing, you get into the problem of infinite regression.Well doesn't saying life originated on another planet/asteroid just shift the problem under the carpet, so to speak?
I don't know where life came from, but I'm not asserting that I do. I am, however, saying that such knowledge isn't necessary when considering evolution, which it isn't.Incidentally, rejecting the idea that you need to know where life came from to believe in evolution is a bit of a cop out.
It's not like saying that at all, because evolution has absolutely nothing to do with creation, nor the beginning of our universe.It's like saying "I believe in creation, but I don't need to know who did it or how to believe that I was created. I'm happy to just believe in creation; whether that was by aliens or god or the F.S.M. matters not."
Why do you assume god is listening/cares/is a murderous nutter?
I will prove right now that there is no Bhavesh Patel.
If there is a such thing as Bhavesh Patel, then let him strike me dead right now.
Nope, nothing, I'm still here. Therefore, no Bhavesh Patel.
Yeah but apparently you can't spontaneously get living organisms from non-living matter in any environment of your choosing, as I understand it.
If you can, then show me where it's been done.
It's not spontaneous, it's a chemical reaction.
Look around you.
Put it this way, I've seen the words come out of each of their mouths several times, I've read the written accounts of both of their beliefs in both the God Delusion, and God is Not Great. I feel I can go so far as to say that they wouldn't have published such a thing as their opinion, if it wasn't their opinion.
Son of a!I can't believe you did that! You've read about their beliefs? So they are beliefs then? Freudian slip or genuine mistake? You decide.![]()
I don't believe that answers anything. Look around you.
Proteins used in living orgs are made from exclusively left handed amino acids, so I read. (Hint: I'm not a biologist). Yet if left to chance LH and RH amino acids would exists in equal numbers, and they do chemically bond with each other just fine.
However, proteins made of LH and RH aminos are useless, apparently (don't ask me why?) So you need somehow to exclude the RH ones.
Which is like saying you need to roll a 6-sided dice and guarantee only even numbers will occur, over however many rolls you need. Which is hundreds? Anyone know what the simplest protein molecule requires in terms of #amino acids?
Man I should really read up on this stuff, again. But I'll just forget it, again.
Son of a!When I say beliefs, that includes unbeliefs as well.
belief in a negative is still a belief.
Which is why Atheists don't believe in a god, they don't believe in no god.
