Evo, E39 M5, E46 M3 or FD2?
Cheers for the info. If I went for one, it'd have to be black, silver or blue with black interior. Coupe, no sunroof, 18's if poss and manual. When did the facelift start and what were the major changes?
As above, April 2003 - but this is a comprehensive list of changes anyway:
Mar-01
• E46 Introduced to the UK
• Brushed Titanium replaced by Titan Shadow
• Business Radio with MD added (Europe)
Jun-01
• SMG-II Option Added (Europe)
• 19” Wheels Made Available (Europe)
Jul-01
• 19” Wheels made available (UK)
September 2001 (Model Year 2002)
• SMG-II Option Added (UK Only)
• Seat Width Adjustment Made Standard (UK Spec)
• SatNav Screen replaced with Wide Screen Model
• Auto-On Lights Added as Standard (UK)
• Individual Options permitted (UK)
• Standard Xenon lights upgraded to Bi-Xenon
• Black Gloss Interior trim discontinued (Replaced by Titanium shadow)
• Minidisc Option Added (UK)
Oct-01
• SMG Paddles Changed (Size & Colour of + and -)
Jan-02
• Minidisc / CD option combined with Nav/TV made possible.
February 2002 Changes
• M Racing Strut added to Coupe & Cab
March 2002 Changes
• Brushed Aluminium Interior Trim Added.
• M Rear Wing Spoiler option added (As on 330Ci Clubsport)
September 02 (Model year 2003)
• Cab Central Brake light made clear
• SatNav Control unit upgraded to DVD player.
• Bluetooth Phone Kit added.
• Interior buttons changed from printed to embossing.
• AUX Connections added to TV Unit
April 2003 Changes
• New LED Rear Lights Added
• Silver Grey Paint Added
• Mystic Blue Paint Added
• Steel Grey Discontinued
• Topaz Blue Discontinued
• SMG Logo removed
• Cabs now get "convenience opening"
• Climate Control Buttons changed
• Brushed Aluminium Interior trim added (UK)
• Boot lid handle changed
September 2003 (Model year 2004)
• SatNav CD replaced with DVD including TMC
• Le Mans blue added to Individual range of colours (UK)
September 2004 (Model year 2005)
• TV Module upgraded to digital
• Business CD Head Unit upgraded to play MP3
• M3 CS Model Added (Europe)
• Interlagos Blue Paint Added
April 2005 Changes
• Phoenix Yellow dropped
• Laguna Seca Blue dropped
• M3 CS model introduced (UK)
• Interlagos Blue Paint Added (UK)
• 3rd Point seat belt and headrest added
September 2005 (Model year 2006)
• CD Changer upgraded to play MP3
My aim was to get a subtle looking car on the outside (so not to attract too much attention) with a silly interior. A black/silver/blue car with a black interior will look very subtle on 18s (the 18s are better for ride quality and handling too apparently) - worlds apart from something like a Laguna Sega blue cabrio on 19s.
Carbon Black, same as my first one, epic colour.
Based on your requirements i'd forget about an Evo.
Unless you are die hard, balls to the wall, and think comfort is overrated, an Evo + a 30 mile commute is a mistake.
The Evo X is easier to live with for both servicing costs and comfort, but is slightly out of your price range. Based on your requirements and the more suitable alternatives available, I couldn't recommend one.
Nick, are you planning to extend the warranty once it runs out? Have you used it yet?
It ran out about a month ago ;)
I never needed to use it. I thought about getting a WD warranty and discussed it in depth with a my friendly BMW Independent who recommended that I didn't bother with a warranty, but rather stash a bit of money under a mattress.
They see a lot of e46 M3s and have had only one VANOS failure (which is usually very rare in the e46 M3 - incorrect oil type used maybe?) and one SMG pump failure. Other than that the M3 generally doesn't really fail on unique things. It snaps rear coil springs like the rest of the e46 coupe range and the Rear Trailing Arm Bushes tend to need doing before 100,000 miles, but other than that it's a pretty solid car.
There are also so many of them about (and have been around since 2001) that even in the worst case, a replacement engine can be found on eBay for less than £2k.
I've owned many BMW's and no one seems to have mentioned the appalling lack of rear leg room in the 3 series. This has been a problem since the creation of the 3 series.
I used to own a 540i Sport till a chav "borrowed" it. The E39 is so much more versatile than the 3 series, it just has so much more space and comfort.
M5 gets my vote. Also, I remember if you get a pre 2001 model you only pay £180 car tax, anything later you pay £450.
Good point about the tax.
I'm not too fussed about room in the rear - you ever been in the back of a DC5?
Vanos failed on my first M3 at 42K ish which I am CONVINCED was because the garage did something during the service 2 where they take the top of the engine off and adjust stuff and few 100 miles after that out of the blue I got the dreaded rumble and a new Vanos under warranty.
RE: The M3 posted on the previous page
Is it just me, or does Carbon Black really wind anyone else up? I mean, it just isn't black.
Left a spanner in the works. ;):p
Isn't it £190ish, and isn't that only on prefix style plates? It will be £215 on all e39 M5s. The new tax rate only kicks in on 2006 cars.
FWIW, the tax on my M3 is £215pa.
Also, you don't care about legroom when it's this pretty :p:
One thing to note is that all e46 M3s have folding rear seats - whereas few (if any?) e39 M5s do. Try visiting Ikea in a BMW saloon which doesn't have folding rear seats and you will quickly re-assess your definition of a practical car.
