Which Card!!
vapor x runs very quiet and at very low temps, i would presume it would have the most head room for oc too. I heard a couple of times that you can't use voltage tweak on these, so its worth double checking.
Can the voltage be used with the reference design one? and would it run fine with auto fan ?
You can flash the bios on the reference ones to either the Asus or MSI bios and then you can tweak the voltage, but you can't on the non reference design ones.
The reference ones run just as cool but a little louder, you'll only notice it when gaming though as powerplay will drop the clocks in desktop mode.
Oh ok cool.
Is There a Guide on here that runs you through the flashing the card.
i've flashed motherboards before, but not cards..
by the way, what's powerplay :p
Cheers.
