Jellyfish lens if anyone wants to check it out
http://www.youtube.com/watch?v=o00QxbDoFyE
Didnt seem to do much.
The second camera i got was also a type 3. The bay users i used were
ebuy4all and power-gps
Looks better without.
Where did you get your cards from hotwired?
My vid, commute to work in the morning. Had to trim it from 25min due to the 10min limit and couldnt be arsed with multiple uploads. It was sunny and youtube makes video quality look far worse than it is.
http://www.youtube.com/watch?v=QVVc_UHstU4
That really is shocking, it's like Beirut in the late 80's!Those roads :S
Almost looks like driving around some dire third would country!
Just got an 8GB PNY microSD card in the post today to use when the camera arrives, anyone know if these are any good?
[Death];16359235 said:right need another for my nephewwheres the best place for a #3 now? i see the uk seller is out now
Ones from hong kong are the only option at the moment but im sure there will be some uk sellers appearing soon when theyve got a load imported
If this is mounted in a car:
a) Is there a way to keep it charged by plugging it into the cigarette lighter?
b) Is there a way to clear the card without having to take it to a PC and plug it in? ie Can you just hit a button to wipe the memory?
This way I can just mount it to my dash and never have to worry about having a crash again as video evidence is always at hand! (Unless its my fault lol!)
You buy if from the UK, but you will be paying through the nose
http://www.iviewcameras.co.uk/Car_A...era_808CAMERA/version.asp?refsource=IVfroogle
£90 here
http://www.flyonthewall.uk.com/car-key-fob-dvr-camera-16gb-vga-p-341.html
I ordered last week on the weekend, still no show... Not going to be impressed with a 2 week delivery
ags
Got back from a cycle round town.
Few things.
Needs a LOT of light. Lots. I have a very bright front light but the camera is incapable of picking up anything illuminated by it unless its reflective, very close or just large simple shapes. Probably need a few thousand watt light. Since mine is 2 watts, it's a bit short.
Works OK on decently light streets.
Went off road down some paths and you see zip diddly squat except the occasional bush or whatnot going past out of pitch darkness.
Also, the recording was broken into two files. I didn't touch any controls but when the initial recording reached 1.38GB in size it stopped and the camera started a new file. Missed a few frames in the time between the two files but not much.
