According to this post
http://setiathome.berkeley.edu/forum_thread.php?id=59329
there is a <use_all_GPUs> in the cc_config.xml file field that might help???
I don't know on this one as I have yet to try and run multiple gpu's in one box
YET.....
YET.....
		 I really need to plan better) Tuesday's the servers are down for maintenance and i stuggled to get any WU's on Monday as well this week. It may be worth setting boinc to not allow new task, clear the cache and try the optimised app again when you aren't gonna lose anything.
 So might end of getting another mobo for it, at least then i can oc it as the old one had bios locked because it was part of a pre built, its been a rough few days but hopefully my output should increase even with the one machine
