Hey guys,
My friend and I are installing BF2 on VMware as you can run multiple instances on one machine.
His has installed fine and is able to run 2 copy's at once.
I on the other hand have opted to try this on my laptop.
I have installed 2 XP Pro 32bit VM's and BF2 is installed with patch 1.41 and 1.5.
When i try to load BF2 on either of the Vm's the screen goes black then 'crashes to desktop' (only the VM not the whole comp)
I have tried increasing the Ram allocated to that VM but no joy.
Here are the specs:
Original Laptop:
Intel T5870 Duo Core 2GHz
4GB Ram
Windows 7 Pro
Integrated GFX I guess (Intel GMA something)
VM Specs:
XP Pro 32bit
10GB Hdd
1gb Ram
Both CPU cores enabled
Is it not working just because of the fact its on a laptop? or is it an issue that can be fixed?
I would like it to work on my laptop as I can just close the lid and let it run without interfering with my desktop.
If you need any other details to come to a conclusion please just ask.
Thanks a lot.
Em
Here are the specs:
Original Laptop:
4GB Ram
Windows 7 Pro
VM Specs:
XP Pro 32bit
10GB Hdd
1gb Ram
Thanks a lot.
Em
		 ) and also the old GTA. I can't imagine the intel GMA will help matters much neither.
