This sounds exactly what I need to do - how do you merge contacts?
It's best to do this on your PC. Log into gmail select contacts click on my contacts and should get an option to merge all contacts. Or if you want to do it yourself select all contacts tick the check box next to each contact you want to merge into one and select merge. Repeat until your finished or bored. Once you've finished you should find the phone has been synced.
