Hmm anyone finding pinch to zoom is broken if you install Swype?
I had that problem, I'm avoiding Swype till its sorted, shame realy as I sort of liked it
I had that problem, I'm avoiding Swype till its sorted, shame realy as I sort of liked it![]()
All you have to do, is reboot your phone and swype will work along side pinch to zoom.
...i havent got tons of apps installed on my Desire...anyhow i then found an apk file which downloaded to my phone but couldnt open it or install it...tried using ASTRO file manager but no go.
.How do you get Swype on the phone??..i tried downloading the file from xda but my phone said not enough room...i havent got tons of apps installed on my Desire...anyhow i then found an apk file which downloaded to my phone but couldnt open it or install it...tried using ASTRO file manager but no go.
So if anyone has a version that actually works and also tells me how to get it working on my phone it would be mucho appreciated.
I presume you have checked the Settings>Applications>Unknown Sources option?
I work in IT support, a reboot is the first thing I triedAll you have to do, is reboot your phone and swype will work along side pinch to zoom.
Check the space left on your mobile using Astro File Manager, perhaps you've filled the phone without realising?How do you get Swype on the phone??..i tried downloading the file from xda but my phone said not enough room![]()
No joy however.
No joy however.
anyone know of an app wherei can tether the 3g connection to make it into a wifi router.
ive just made a move to android OS. on windows mobile there was a wifi router app that utilised the 3g connection and gave off a wifi signal to connect to. got it from xda developers. is there something similar for android
Trying that out now. Could be useful as and when I get a netbook.As far as I know there is not a wireless one but the one I and many others use is called Pdanet.
You need to connect your phone via usb though.
 Key is in the name, root users only
 Unfortunately I've found no way to secure it properly
Well unless ive filled over 63mb of space with one app since fri...i cant see why i havent got enough space.
Anyone found a game similar to Unblock Me on the iPhone ?
