- 23 Apr 2009
- Cheshire
pc2 3200
Ok cool - so your one does use DDR 2 - 400MHz (ie. PC2-3200) stuff at the minute. If you want an upgrade - your board does support DDR2 PC2-4200 (ie 533MHz) stuff, which will be a bit faster.
I would suggest upgrading to a DDR2 PC2-4200 2GB (2x1GB) kit if you want to give your memory a boost. A kit like this is generally pretty easy to find using Google, unfortunately OCUK doesn't sell this RAM any more (unless you want to risk going for a faster-rated 800MHz kit and hoping it defaults to 533MHz or slower when inserted).
