if res 5 is anything to go by then having it off does lower image iq slightly.if you look closely you might see that edges are a bit fuzzy even when you use AA.
advanced can also sometimes lower iq but ive never took the time to study it so as a rule of thumb standard is the best option 24/7 UNLESS you run into problems like GTAIV.
still sucks tho doubtful it will be patched either
