Medium gaming laptop
25 Oct 2009
I'm buying a medium standard gaming laptop because I need lappy for work but I want it for recreational use too. I don't need an alienware goliath machine.. just something capable of running games reasonably well. Are the following differences worth the price changes?
Intel® Core(TM) i3 Processor [ - £ 50.0] Processor i3-330M (2.13 GHz) with 3 MB L2/L3 Cache
Intel® Core(TM) i5 Processor Processor i5-430M (2.26 Ghz) with 3 MB L2/L3 Cache
Intel® CoreTM i5 Processor [ + £ 50.0] Processor i5-520M (2.40 GHz) with 3 MB L2/L3 Cache
Is the i5-430M that much better than the i3 and would the i5-520M be worth the upgrade?
4 GB 1066MHz DDR3-SDRAM 2 x 2048 MB
6 GB 1066MHz DDR3-SDRAM [+ £ 99.99 ] 1 x 4096 MB + 1 x 2048 MB
£100 is a lot for 2 gigs of ram...
ATI MobilityRadeonHD5470 512MB [- £ 50.0 ] ATI Mobility Radeon(TM) HD 5470
or
ATI MobilityRadeon HD5650 1GB ATI Mobility Radeon(TM) HD 5650
I'm assuming this is totally worth the extra £50...?
39.4 cm LCD, 1366x768 + webcam 39.4 cm (15.5") VAIO Display (1366 x 768 pixels) (16:9)
or
39.4 cm LCD, 1920x1080, webcam [+ £ 39.98 ] 39.4 cm (15.5") VAIO Display Plus HD1080 (1920 x 1080 pixels) (16:9)
HD not worth it if not getting a blu ray player in the laptop? Is a blue ray player even worth it?
DVD disc drive Reader / Writer (DVD+-RW/+-R DL/RAM)
or
Blu-ray Disc(TM) player [+ £ 50.01 ] Plays Blu-ray Disc(TM) (BD-R/-RE/-ROM/ DVD±RW/±R DL/RAM
Total Price
£ 659.01 inc. VAT
£ 560.86
(Chose 320GB HDD instead of the 500GB because I don't DL loads of media/prawn)
Toshiba Satellite A500
i3
GT 330m
Perfect ran mw2 at high for me today around 60-90FPS
Counterstrike High at 150-200fps
I'm sorry that's over 300 pounds more expensive for a GeForce 330 instead of an ATI 5650. That's a ludicrous jump.
Can anyone answer my questions relating to the comparisons in the OP please? :)
The i3 is a dual core, and the i5 a quad core. For gaming, it won't make much difference, but for general user and applications I'd go for the cheapest of the 2 i5s.
Graphics wise, the mobility 5650 is a much, much better chip than the 5470. If you plan on getting the 1920 screen, you NEED the better graphic card, and I'd recommend it even with the lower res screen.
Regarding the screen resolutions: This is very highly personal, there's no right answer here.
if you use the laptop primarily as a games machine, the lower resolution screen might be better - so you can crank up the settings in games, while the TFT display remains crisp (TFT screens don't look as crisp if you lower their reoslution - though having siad that, some people like the free pseudo-anti-aliasing you get when running at slightly below maximum screen res).
If you use the laptop a lot for non-gaming applications, the higher resolution can make a lot of difference. That said, at 15", 1920x1080 might be a bit too high. I had 1680x1050 on a 15" monitor, and most people I showed it to thought it was too high a resololution for the screen. I liked it, but going up to 1920 would probably have caused me eyestrain.
So, it's a tough decision. I edge towards recommedning the 1366 res (even if you choose the better graphic card), but if you are confident of being able to read lots of really small text, and you use a lot of spreadsheets or paint programs or similar, go for the higher res. Oh! Also, if you plan to use it for the very highest def multimedia, you'll need the bigger res screen. The low res will be fine for 1280x720, typical hi-def, but for 1920x1080, you'll obviously need the bigger res. If you aren't sure which of those you might need, you don't need the big one.
Regarding the Blue-Ray drive: this is a pointless luxury in a laptop at the moment, for most people. If you expect to be using the laptop as a multimedia player and planning to buy a lot of blu-ray disks, then it is worth getting - otherwise, it's a complete waste.
Almost missed the RAM question. You definitely don't need more than 4GB RAM - the price for an extra 2GB is way more than the possible benefit you'd gain from it, which would be only in very limited circumstances.
If there's one option among all of those you do take - make sure you get the 5650. It's totally worth it.
I hope this helps!
i5 isnt quad core, its dual core with Hyperthreading. so 2 physical cores with 2 virtual ones.
have to say for £700 the Toshiba with I3 and 330M graphics is a great price.
Yeah. I actually got £50 of due to a mates staff discount. Running games great sofar. Was on 91 constant. Didn't flicker once, fraps told me it stayed there for 15mins!
Very good machine.
I am interested in the same laptop but i'd probably get the i5-520 however what puts me off is the estimated delivery time of 4-5 weeks? Will it really take that long??
I looked it up. Some i5s are quad core but not those displayed up there. I'm going for the 5650 card, 4 gigs of RAM, Lower res screen, no blu ray player. I don't need to play MW2 at 91 FPS. That's nuts. I currently play some games on my current machine at 17FPS and that's almost good enough for me XD
I've looked up the GT330m and I think the 5650 would suit me better. The last thing to pick is the processor. All 3 are dual core. I don't understand what hyperthreading is. Could someone help me out on this? Are the i5s (not particularly top end i5s) worth £50 or £100 more than the i3 given they're also just dual core? I doubt I'll need more than an i3 on my laptop... but I don't know! ^^
edit: Snarf, I don't know. I'm going to call them up and see what that's about because that seems a bit excessive.
i would personally go with i3/cheaper i5, 4gig ram, 5650 and lower res screen.
might look a bit on the grainy/blocky side, but the many more fps would more than make up for it.
I've been doing my homework :)
i3 and i5 M benchmarks
The i3 has a number of features disabled, like TurboBoost, which is a very handy feature for a gamer. It probably means the i3 has slightly longer battery life, in normal usage (not gaming!). Personally, I'd go for the lower of the two i5's, but there isn't much in it.
One final tip: make sure you get a 64bit version of windows. Some of the 4GB of RAM will be wasted otherwise.
i find 64bit windows a pain in the backside.
id rather lose half a gig than find half of my peripherals (including both my wifi adapters...) and half of my programs dont work
I'm guessing this is the Sony Vaio Series E laptop your looking at, if so I bought two of these on friday (one for me one for gf) got the production confirmation on both today so will let you know how they are on arrival.
I went with:
Intel® CoreTM i5 Processor Processor i5-520M (2.40 GHz) with 3 MB L2/L3 Cache
15.5" VAIO Display (1366 x 768 pixels) (16:9)
500 GB Serial ATA
This spec came to £750, the gf stuck with a 320gb hdd which came in at £709.
I didn't bother with a FullHD screen on a 15" laptop as from experience on other machines of this size I've found 1920x1080 to be overkill and completely unnecessary, 1366 x 768 feels just fine plus when it comes to games you may find full hd a little too much for the laptop and so need to run at a lower res and running on a lower res than native always looks awful.
The 5650 card is quite capable and altho in the sony laptops they have clocked the core at 450mhz instead of the usual 550 - 650 other owners have posted that they have nps overclocking the core to normal speeds using various gfx sortware programs without heat issues.
I think delivery will be a couple weeks but if you still havnt purchased by the time they arrive i will post some benchamarks or whatever you would find useful.
i3 would be perfectly adequate for gaming on a laptop and have the advantage of less power usage, less heat, etc.
The res is a tricky one - 1920x would tax a mainstream laptop GPU too much and it makes things quite tiny on your average laptop display, but IMO 1366x768 is too low res - while that does makes the lower end GPUs more useful I think for general windows useage you'd find it cramped and some games suffer i.e. mmos like eve, wow, etc. tho not such a big deal with fps games. Personally I settled on a 1680x1050 res on my laptop and find that works very well.
4Gig of RAM should be fine for even fairly high end gaming and normal laptop tasks, you need to be doing some fairly serious video/image editing, etc. to make a case for more than 4gig.
I'm not a fan of ATI laptop GPUs personally - often they put a great core in but cripple it with slooooow VRAM, I'd advise looking at the nVidia options if possible, they tend to run a little cooler generally too.
Interesting stuff JonnyCasino... So they didn't give you a more accurate delivery time? I'll probably order one this week anyway! :)
