Hi, my PC has an ATI 5870. I am willing to bet that that is why I can not engage all of the Graphics settings to "Enthusiest" in Crysis.
I am looking for a fix please. Settings are curently only set to "Very High." Fairly positive that I am running the DX 10 version (default).
Also, I was having mouse sensisivity issues with the sensitivity being way too low for my liking. But I fixed that by opening console and typing in:
con_restricted 0 [PRESS ENTER]
cl_sensitivity = 200 [PRESS ENTER]
I made a "System.cfg" document with notepad in the Crysis folder with those 2 console commands. But I think I made a mistake with the second line. I did not put it exactly the way the game likes it. So the next time I opened Crysis, I found all of the settings, including my keyboard/mouse button configurations, had all been reset back to default! Luckily, I noticed that this reset did not affect my one savegame that was auto-saved just when the game starts when Nomad gets on the island via the beach. It was just annoying to have to once again change all the controlls to the way I like them. I use a CRT monitor by using an adaptor that I connect to the back of the PC. It is the connection that is horizontally long. Not sure if that is called HDMI or DVI.
But, once again, I was unable to set the graphics settings to Enthusiest. My resolution is 1280x1024. Thanks!
