Well no actually it wouldn't, an overclocked 5870 still doesn't beat the 480 @ stock in the majority of games, you might want to go and do some research on this, but I'm fairly confident the results are right there for everybody to see.
Go and have a quick look at the 480 end users thread, I think there's some fairly conclusive evidence right there.
You also conveniently fail to mention the 480s clock pretty well themselves, giving some very good results.
Please Kyle, for the sake of my sanity, try and keep your fanboyism in check, I really don't want to put you on ignore because occasionally you do have something of worth to say,
but your constant digs and slating of Nvidia in every related thread is getting somewhat tedious and very monotonous.
All you've done is highlight how flawed "fastest GPU" actually is.
So, why do all the reviews show a 5870 and GTX480 matching eachother very well at stock? Just because there are some games where the 480 still does better, doesn't mean anything. According to that logic, the 5870 is better than the 5970, because there'll be a few games, where crossfire doesn't work, which would give the 5870 an advantage.
There are games where the 5870 at stock, beats the GTX480 at stock, really, to bang on about fastest GPU is nonsense, it means very little.
Is it not fanboyism when you can't hear them be criticised?
You have a GTX480, you surely can't claim that you're not at all biased, at all can you?
I don't just slate and make digs at nVidia, and if I do it's due to something relevant.
To me, I simply can't understand why ANYONE would buy a GTX480. They're bad because they're bad, not because they're nVidia.
I think the 5870s are bad as well, does that mean I'm now an nVidia fanboy because I'm being critical of it?
I slate the 5870 a lot and say it's very over priced for what it is, because it just is, nothing to do with its brand at all.
I don't understand why anyone would buy a GTX470, 480 or a 5870 when you can overclock a 5850 and get the same performance.
