basically the fast tap flow creates a pressure drop (small vaccum), which then the gasses from the liquid come out to equilibrate.
 any idea how long it needs to be left equilibrating?doesn't anyone use de-ionised anymore?
Tried both deionised with a silver insert to stop forests growing, but got bored and went back to green dyed stuff, much more fun and I can see it when it spills.But its non-conductive supposedly.
). I don't think there's a time 'limit' as such and providing the container and pipework is sufficiently sturdy it's difficult to go too far. Make sure you get the arrangement right though so that mavity helps - you want the water to flow past the junction, not into it (otherwise you'll put the bubbles back).Might be a stupid question, but how do you keep the flow rate down?
Tempted by the 'inline res' idea - I don't want a regular res because I move my computer flat-upright way too often so I'd probably create bubbles each time I did that. But with 3+ graphics cards and 7+ HDDs floating around, I really have next to no room for a res at all. Decisions, decisions. Can't do anything at the moment anyway though as my motherboard appears to have died a little and I'm debating whether to sell the RMA replacement and plump for the seemingly promising X58A-UD3R as, tbh, it seems to fulfill all my criteria!
	with a D5 it's easy - set it to 1 or 2
with DDC you just squeeze the tube (or clamp it)
Pinch the tubing.
 that will help next time I have to change something.the air bubs are not from the pump are they? is it not just splitting up a larger air "Cap" put into the loop from the air in your radiator?
