I'm pretty sure in terms of net, no. You might be talking about an isolated inlet or coastline, or something.
All the science of late is actually pointing to the fact that the ice is melting much faster than we'd previously thought in many instances.
In fact the last two years have seen a recovery of sea ice in the Arctic. A good point to remember is that given the entire length of Earths biosphere history, the Icecaps and Ice Sheets are relatively uncommon.
We don't understand the mechanisms enough to make any kind of definitive statement either way.
The temperature records are incomplete and largely based on proxy data which is contentious at best. Too many question marks remain over how the station data is compiled and homogenised. None of the current GCMs include data relating to seasonal or localised climate phenomea such as El niño.
The fact is that the GCMs failed to predict the current static temperature phase since 1998, temperature increases has ceased and have in fact dropped slightly. The trouble is with the language used, we are told that it has been the hottest decade on record, that maybe true, but the hottest year was 1934, followed by 1998 since then temperatures have stabilized, if this trend continues then in by 2020, we will see statistically significant drops in temperature, and not the increases the IPCC models predict. According to proxy data the medieval warm period was several degrees higher than current temperatures, and that cannot be attributed to mankind.
Now supporters of AGW can and will argue every point I made, but the fact that I can make them with evidence to back those claims proves that AGW is an unproven hypothesis to explain a gap in our understanding.
