About to purchase...
16 Apr 2009
I've also added one of these:
http://www.overclockers.co.uk/showpr...=10&subcat=951
EDIT: I will be recycling my Video Card from this PC (4870 1gb) and my PSU.
Any thoughts on it, I've gone for the bundle because i have no experience in overclocking... All help is appreciated!
Cheers,
Azure
Ok then.
Nothing to change.
Your getting that bundle because your a novice overclocker?
Aslong as you know those components in the bundle are cheaper when bought separately.
Ok then.
Nothing to change.
Exactly, I know there's guides out there to help but if im spending £700 on a pc, an extra 40 quid to guarantee a stable overclock is well worth it in my opinion
I didn't purchase it last night, because I gave it some thought and since i've never overclocked before, is it wise to buy a bundle? What if something goes wrong with the overclock... I would have no idea how to fix it....
It will be under warranty.
And they are fully tested before being sent out, the overclock settings are stored within a profile in the bios, so can be selected on or off at any time.
