lsas.blaster.keylogger worm on pc
i can boot into normal windows mode but whatever i try to do i get a message saying ".exe cannot open it is infected with the virus lsas.blaster.keyloger"
i can see the option for safe mode but my keyboard stops responding at that screen, it works fine because i can boot into the bios and everything, it just stops responding at that screen or if i want to boot from cd, it'll say press any key but the keyboard stops responding again... i cant get hold of a ps/2 or usb keyboard so any advice?
What sort of keyboard are you using if it's not USB or PS2? If it's a wireless USB setup, enabling USB in your BIOS should allow you to select safe mode.
Some of the newer nasties break safemode so the machine just reboots.
Can you download mbam? If you've got it, rename the .exe to something else and then run it.
Isn't this just one of those fake antivirus/security scareware things?
What program is telling you that this worm is on your pc?
