- 6 Jan 2010
- Leicester
so i just got my budget a few mins ago what can 600quid ex vat get me
no screen needed
no screen needed
and some more gaming and some h.w =O
any views?
fantastic i like it..so what gfx to buy 5770 or 5830?
and is the mobo xfire compat?
ill be using this hdd that i got atm so on it is win 7 ulti and only like 15 quid over budget
If you don't need harddrive or Windows included it this, then this does seem to be decent out-of-the-box performance for the budget (because of the pre-overclock). Hwoever the motherboard in the bundle won't be able to crossfire properly, because of the 2nd PCI-E only offer 4x.![]()
any views?
You could probably get a Phenom II X4 build (no pre-overclock included- buying parts individually) for that price range.
Phenom II X4 no Crossfire build, with USB3.0 and 6Gb/s SATA motherboard:
Phenom II X4 Crossfire ready build, with USB3.0 and 6Gb/s SATA motherboard:
I would still go for the Zalman Z7 Plus Midi Tower Case instead of the Coolermaster Elite 334 Midi Case
The Coolermaster Elite 334 only comes with the rear 120mm fan, whereas the Zalman Z7 Plus is spacy, well-laid out and comes with front, rear and side, and side-panel fans by default.
AMD bulldozer a proccesor? if not can sumone decipher the message above o.o
It's AMD's new architecture CPUs that's gonna come out in 2011. But would it be a i5 750@4GHz or i7 920@4GHz killer, that is still remain to be seen.AMD bulldozer a proccesor? if not can sumone decipher the message above o.o
