Speed issue
12 Jul 2005
Guys ive got 3Gigs of Corsair XMS2 DDR2 6400C5 ram which i have been using for about two years.
However, im totally unsure as to what speed it should be running at.
CPU-z posts this:
Type: DDR2
Channels: Dual
DC Mode: Symetric
DRAM Frequency: 400.8Mhz
FSB:DRAM: 5:6
CAS# Latency (CL): 5.0 Clocks
RAS Precharge: 5 Clocks
Cycle Time: 18 clocks
Row Refresh time: 54 Clocks
Command Rate: 2T
See anything wrong with that little lot? Anyone know what this ram should be running at?
corsair say this:
CM2X2048-6400C5
Speed Rating PC2-6400
Tested Speed 800Mhz - does this mean that my DRAM frequency of 400mhz is wrong? should it be 800mhz or am i reading into this wrong. Does it mean 2X400mhz = 800mhz?
Size 2GB
Tested Latency 5-5-5-18
Tested Voltage 1.8
Performance Profile
SPD Speed 800Mhz
SPD Latency 5-5-5-18
Package 240pin DIMM
Fan Included No
