Can I get the stability formula as well? [email protected]
my second season, and im finding it a bit easy to be honest.
puma blaze belini spectre
i jumped 40+ leagues from 7x to 35.
)Yeah but fixed now.
Is it sad that I recognise the 5* HQ building as the House the FBI/Cops had comandeered in The Fast and the Furious? :/
i think so just takes longer![]()
hmm going to be trial and error then acid, but if you are developing yer own stuff i would suggest not going witht he jonda chassis, you need to give yourself an edge over yer opponent, so maybe go for better tyres or engine than him instead.
also when developing yer own suff develop i tto the same level i.e
20/20/20/16
on all parts then move up so the best thing to do is look at how much you can upgrade each part by per race then decide on what you want it to be.
then upgrade all 9 car parts to the same level and start again. the reason for this is stability. if you develop one part that is way better than the others it can reduce the stability of the car. the other option you have is to work out what the parts are on the toyo chasis now and improve them all slightly to make the car 100% stable. this would also give you an edge over the jonda chassis as that might only be 75% stable in comparison.
my first advice ont his would be to write down what each of the 9 parts of the toyo chasis are, then add them up. i.e 20/17/14/14 = then when upgrading make them all equal the same that will give a 100% stable chasis.
so if 8 parts - 43 and one is 37, upgrade the part thats 37 to 43 and boom improved stability![]()
if you dont get any of that ill try and explain better however im only just grasping it myself lol
Which chassis is the best do you think in the private leagues ? I have gone for the Mclovin seemed most balanced to me. But im wondering if I should have gone for the Ferrenzi instead now.
Engine wise I chose ferrenzi most are on the mercey but that seemed to unreliable to me and I noticed mechanical problems for some so far.
Also whats with the tyres ive stuck with marathons dont seem like the other offer the all round goodness of them.
