bit of a handful to play COD on though...not much room for the mouse mat![]()
Does anyone have anything over 4GHz stable under 1.3V?
75 c is the sweet spot on air I think
	Well, here's some good news guys. After a year, I replace my NH-U12P SE2 with Noctua NH-D14 and here's the result.
4.2GHz @ 1.2850VCore on an Antec 1200(Fans on low) and Asus Rampage II Extreme board. Who needs water cooling now?
ok would like some input on this one. Got the 930 @ 4ghz and managed to get 50 passes on LinX, but my vcore seems really high compared to the 920's @ 4ghz.
Am I doing something wrong, have I got a duff chip, or do the 930's need more volts? I'm not greatly experienced in clocking, I stuck my q6600 @ 3.2ghz which was easy.
In my screenshot a few posts up I achieved 3.8ghz @ 1.225v vcore, but to get to 4ghz I've had to pump in 1.356v which seems a big jump.
I wish there was more data on the 930's so I could see what others are doing.
4ghz:
@reygjabla..nice clocks at decent volts, would it be possible for you to list your bios settings for
Loadline calibration
QPI/Dram v
PPL v
Very good oc,but you should try stability with Occt,prime and Linx as i have had success on 1 stability test and fail on another...only by testing all stability tests can you really be 100% sure of stability![]()
	Nice setup m8![]()
Liquid nitrogen?
Holy cow that's one big compressor and condensor, what's it tuned for?
You need to post your setting and maybe someone using the same board and cpu would be able to point you to the right voltage settings.
Yeah, sorry I will do later. Im back at factory presets again, and tried a whole load of different tweaks using other ppl's guides but went from a mix of blue screen to no post, to failed Intel Burn Tests.
Will put it up later when I try OCing again.
Loadline calibration = Enabled
QPI/Dram = 1.3000
PLL = 1.89xx
Here's 20 runs of LinX and 8 hours of Prime95 small FFT with VCore of 1.2750.
