Not in the real world it cant.
I think the the best Nvidia card would would be a used gtx285 from the bay. Personally I would just sound deaden your case and wait until Nvidia refresh.
Hi,
Since my ATI 4890 sounds like a vacuum cleaner and pretty much constantly runs hot, I've decided I'm going back to NVIDIA. However looking around it seems the only viable in stock option (without spending crazy monies) is the 260 GTX. Is that right? Everything else seems to be out of stock.
My ideal price point is £200. Any advice would be most appreciated. Thank you
Fermi cards arnt that loud. Its only when the fan goes over 80ish%.
Oh
So what's the quietest solution at the moment then please? The 5850?
I hate to point out the error in your logic, but the Fermi cards aren't exactly quiet.
Your 4890 is too hot and loud so you're buying a Fermi based card?
Ik now the fermi cards are really loud by comparison to 5800s - every reviewer has commented on it. But videos like that are a bit pointless since we don't know what his volume is set at and our volume may be set differently. What we need to see is the same reviewer do both Fermi and 5800 series cards, in the same video - maybe one after the another, or cutting between them - so we can hear the real difference.
I have a 480 and its not loud at all
Even when playing Battlefield bad company its quiet.
I think they only become loud when stressing them through benchmarking programs.
But general gaming no problems at all this end
Most of the noise comments are silly really as most PC fans are far more noisy lol
Some people like getting the most performance out of their pcs. Some like making them as quiet as possible. Everyone has their own niche.
What? it will put up a good fight against the 4890 - sure it won't beat it overall but it will make it work for the advantage the 260 is often only 10% slower probably 15% overall.
Wow. This way Radeon 5850 puts up a good fight against 5870 - £85 difference
5850 then puts up a great fight against 470GTX - £75 difference
5870 puts up a good fight against 480GTX - £135 difference
This logic ain't good because 260GTX is more likely on pair with 4870, isn't it?
An aftermarket cooler is the way to go. This Akasa AK-VC03-BLUV or Zalman VF-1000 would suit you well.
