S2000 Info Please :)
Same paragraph:Seems it would also demonstrate you can't read :p
I know where it was introduced and where it stays, I'm saying if this guy is so adamant that it's an AP2 then he can just check the tacho!
But there are categorically NO AP2 engined S2000's in the UK unless they're RHD imports from America.
I say it again, we have some AP2 with 2.2 engine at work, why is it so hard too believe?
what if I told you there is also a yellow FN2 floating about?
Seems its my postcode!
If I put my brothers in (he lives above York) the prices halve from £1300ish to £650.
Even though the car would be in a locked compound, at the end of the dead end road, with a 15 foot wall all the way round and the car not visable from anywhere but inside the compound!
25, 6 years NCB, Central London, £700 FC with a long list of mods.
Chris Knott, very fussy on requirements to get cheap quotes it seems.
Regarding the chassis code off the dash, well done. Can you take a picture of the one with the engine code please. F20C will be written there
I've had my s2000 4 years. I got it tracked just after getting it to make sure all the wheels pointed in the right direction. It's been fine since :p
seized bushes are only a problem if you want them to be.
Pic of the VIN plate in the engine bay and we'll believe you.
Im 25 / 3 years NCB / Good postcode area and im paying £800 fully comp for insurane through elephant. Some insurance quotes here are mad!
im 27, 6 years ncb, and pay £525! thats with chris knott.
they might refuse to insure you unless you have driven a fast rwd car for a year before.
