64Gb Memory stick help.
18 Oct 2002
Nottingham
Hello,
I have a 64gb Flash Voyager memory stick made by Corsair :) had it a few weeks.
The problem is the stick keeps loosing files i saved to it :(
Using Win XP Pro with SP3.
Drive properties report 62.4Gb total space. In NTFS file system.
Used is 3.62Gb videos, documents, pictures etc but them on last night.
Today plug it into my computer all i can see is 1 file 32Kb in size :confused:
Its done this before but seemed to fix itself.
Any idea what could be wrong with it ??
Many Thanks
Ben
This probably seems daft, but have you made sure you have ticked view all files and folders from the options? Had a similar problem with my girlfriends usb stick and this was the solution.
