- 13 Nov 2007
Why does it look like in your first picture, that you've bent your case above the CPU fan?![]()
Ah yes ... the bend facilitates better air flow of course! If you think that is novel, you should see my lounge
(It is bent around my case).
so loop to drain and put EK back plate on this time.
