- 18 May 2010
I have an OEM copy of Windows 7 which I installed to my PC to get rid of Vista, that was a only a couple of months ago though and i'm in the process of building a new PC
Will I be able to use this copy on my new PC as my old PC will be stripped and sold off, you used to be able to do this, not sure if you can now but I hope so as I dont see the problem i'm only using one instance of it and it was/is expensive
Thanks
Thanks
