You can run nVidia 3D on any card above a 8800.
To run their new 3D surround (3 monitors + 3D) you require 2 cards in SLi or a dualcore gpu (9800 GX2 or 295).
The driver for this haven't been released yet so benchmarks are topsecret / non existant
gtx 480 is certainly powerful enough to do 3D justice and 16xaa is completely pointless in 3D, just cause 2 runs fine here on a single gtx 480 in 3D
40-45fps is pretty useable with 3D Vision.
Another phenomenon is aa. It seems like i can lower it and still have the same effect. Game without aa in 3d vision feels like a game in 2d using 2-4x aa. For me anyways.
3D vision is fine on current hardware, only ATI lovers say otherwise or people without a clue. Not real people who have it & use it.
3D vision worked perfectly on my old 275 and now works even better on my 470.
All games run very well in 3D, with all settings maxed at 1680 x 1050. AA isnt required as 3D gives about the equivalent of 4AA on its own. Metro is the only game I can not max in 3D with my 470. SLI is not needed unless you want to use 3D surround.
My 470 plays games in 3D faster then my 275 played them in 2D!
1680 x 1050 is a low res
3d is 2xaa not 4xaa
sli is needed if 1920 x 1200 or greater in certain games
says someone who admits he's never used it
. Go crank up BFBC2 on the settings you use without 3D and then come back and type some lies to me if you are not man enough to admit you are wrong. Just Cause 2 is a major problem also as if you turn GPGPU on for the water effects it renders SLi null and void and that already takes a hit on FPS. So now try turn on 3D with SLi off and running GPGPU water effects
. Again, another instance where it shows you the limitation. This is just two instances which show your post to be nothing but flame bait. This is from me who actually loved playing with it and from my friend who loves his new 3D environment. Even he admits he needs SLi'D GTX 480s to run this how he wants and this is with already owning the GTX 295.
