Started Firefox up using the safe mode switch and I was able to copy my char, thanks for suggesting it may be a browser issue. I don't actually have IE8 installed atm
I installed and updated but when accepting the user agreement get a Interface / LUI yada yada error, any else had this and know a fix?
I would post on the cata forums but having troubles copying over chars at the mo, seems to say it worked OK but hasn't took the number down from 5??
According to the forums you can workaround that issue by wiggling the scroll bar but i couldn't get it to work.
Managed to fix it by manually going into the config.wtf in the beta/wtf folder and changing the -1 at things like "set readtos" to just 1.
Char copy numbers don't ever drop, i assume it's because the alpha/beta doesn't limit your copies in the interests of testing.
