Thought i'd share this with you
I've been playing BC2 on my old PC since release day, I had to force DX9 and run most settings on low with no AA to get decent FPS on line, my latency would be anywhere between 160 and 200 depending on how busy the server was, if was too busy it would go over 200 and be unplayable
So what I hear you think...
I built a new PC this week but i'm using the SAME GPU. Last night I install BC2 and i'll be honest I didnt expect that much of difference but I thought i'd try letting it apply the default DX10, put everything on high, 4 x AA and loaded a game up, this is in 1680 in both cases. I was wrong, the difference is incredible, everything is smooth the graphics are better and my latency is lower, ive seen it as low as 90's and as high as 150 but usually around 120/30. Plus I noticed weird things too, theres more voices and sounds, weird but there is.
Thought i'd let you all know, seems the game is more CPU intensive than I realised and if its been mentioned already apologies but this thread is nearly 500 pages long
Ironically I played crap all night because I cant used to it
