Fingers getting thin?
Are you sure it's not just in your imagination? Do you have before and after pictures of your hands so that a comparison can be drawn?
Maybe you could try something similar to the Greg Valentino approach for increasing the size of your fingers...
Lady pleasing thickens them up in no time. Get to it! For even training i would suggest finding a women that can fit all five at the same time.
Do you have any other wierd symptoms, such as unexplained scarring on your back or stretch marks for someone who shouldn't get them?
Recently after looking at my fingers, I've noticed they are getting pretty thin now. Before, they used to just be 'normal', but now the knuckles look kind of big, whilst the part where a ring would sit and the ends curves inwards now due to how thin they are. You can also see the veins in my fingers whereas I couldn't really before.
I do crack a lot so I thought it might have been down to this. However infomation on the Internet seems to suggest I'd be wrong.
What on earth can I do to make my fingers thicker and back to how they used to be? They look terrible now. :/
Thanks. :p
Definitely is this
on a serious note arthritis causes swollen joints, so it could be that you knuckles are getting bigger not your fingers thinner. Any pain or RSI type symptoms? Arthritis does not just effect old people.
Too much internet, keyboard is stretching them :D
But in all seriousness go to your doctors this surely counts as a medical thread. Thinning of the bones (assuming that is the problem here) can be a symptom of a lot of things, some as simple as just getting older, some very nasty indeed if left untreated.
No pics, but they were definitely thicker before. I've got some metal ring thing off my desk which used to be tight around my middle finger before, but now it's really loose.
If you're wondering why I was playing around with some metal ring off my desk in the first place, well I was bored. :p
Hilarious.
OP, hows your circulation?
Fine I guess. Everything feels normal, it just doesn't look it. :p
Nope. :p
No pain or anything.
I think I'll go tomorrow. I'm only 19 so not exactly old. :o
have you started to wear a pointy had and long purple velvet cloak with starts on it ?
Are you fighting the urge to grow your hair long, dye it grey and carry a drum stick around with you ?
if the answer to any of the above is yes, you might have wizarditus
Get out or I'll turn you into a frog.
