.Yes, I already knew about this before ordering the Asus R3E.
Here is a list of the hardware components i've ordered so far for my new computer system.
I`m going to use my old EVGA GeForce GTX 260 in this system temporary until I decide on what high end Graphics card I want for the system as that is the only thing I need now before the system complete.
Intel Core i7 980X 3.33GHz (Gulftown) Extreme Edition (Socket LGA1366)
Corsair Dominator GT 6GB (3x2GB) DDR3 PC3-16000C8 2000MHz Triple Channel Kit (CMG6GX3M3A2000C8)
BeQuiet Dark Power Pro P8 1200W Modular Power Supply
Creative Sound Blaster X-Fi Titanium - Fatal1ty Champion Series 7.1 Sound Card (70SB088600005)
Logitech G19 Gaming Keyboard (920-000978)
Noctua NH-D14 Dual Radiator CPU Cooler (Socket LGA1366LGA1156LGA775AM2AM2)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
Crucial RealSSD C300 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC256MAG-1G1)
Asus Rampage III Extreme Intel X58 (Socket 1366) DDR3 Motherboard
Coolermaster RC-1100 Cosmos S "Sport" Silent Full Tower Case - Black
Roccat Kave 5.1 Surround Sound Headset
Logitech MX518 Gaming-Grade Optical Mouse (910-000616)
Boogie Bug AimB.Pad XL Gaming Mouse Pad
Arctic Cooling MX-3 Thermal Compound
OcUK Value 2.5" to 3.5" Hard Drive Adapter
Just curious to know, are you going to leave out the heat spreader on the RAM and the fan on the North bridge? Won't it cause problems? Just curious to know as i'm planning to OC to 4Ghz and run my Dominators at 2000 Mhz. really wanted the Noctua, but if both parts are fine without their Heat sinks i may consider getting it again.
. - Must be the BIOS surely?
is regarded on i7 that higher mutli needs more vcore then BLCK thats normal. hence a lot of people not using turbo mode as it need more vcore![]()
Will re-run with Prime95 for a bit and then I will move onto tweaking the RAM.Simulatorman, if gives that error because it detects the fan RPM is too low![]()
so if u linger in the crucial forums like i did ull prob learn more and then can help me out.2- c300 has a new firmware make sure u update as its a great improvement. you have more knowledge than me in computers am very noobiso if u linger in the crucial forums like i did ull prob learn more and then can help me out.
I have one major issue and that is the Marvell 6G controller and Crucial RealSSD C300 256GB performance on this board. I have suffered a 30% drop in performance compared with the same SSD on an Asus P6X58D. Under investigation.
that is when I stopped as I was scared to increase the voltages any more haha. I got SO close to 5GHz, posted with 4.8GHz with hyperthreading, but to get to 5GHz would require a lot of patience, tweaking, and more voltages.
