Caporegime
- 12 Mar 2009
Some of the later journal challenges are real ball busters. Disarm 5 people without reloading. :-/
Yes, I'm pretty sure it's accurate
Note about Bounty Hunter missions: my last three in mexico where randoms (faces where blank and marked with a ? symbol), they still counted. So check your stats to see where/if your short. This confused me for a while.
Its 6 actually.![]()
Trying to do that one now. I'm finding rank 5 of master hunter hard. Have to kill 2 cougers with your knife.
Stats>Score and then push up one click (d-pad or left stick), thats the fastest way as they are listed at the bottom of that section. BH missions will continue to be posted even after an areas completion quantity has been completed.Sweet, nice one.
Where is the option to check how many bountys you have done? Also do you know it once you've done the 20 then no more respawn?
I still need the trophy for poker.
Do tell. It sounded ace for the 6 or so seconds it played before cutting out!
Maxed out perhaps? Make a save and then do something that will effect it. If you've been good, be bad.i seemed to have lost that bar that comes up when you do a mission and has honour on,i had it all way through armidilo and now its gone and ive done all mexico i havent seen it since
just got drunk and passed out in the middle of the street.
