Well my PDAir case and windscreen mount arrived today from Hong Kong. Initial impressions...
The case itself feels solid and like a quality product, it comes in a nice presentation box with a removeable belt clip attachment.
The case is hinged along the bottom edge. I can see why they've done it, because the top is mostly open but it's a little annoying as it hangs down. The case must be open if you wish to slide the screen up, the phone is still held securely in the case even when it is open.
The belt clip attachment itself is a little annoying as it protrudes by about 1CM and makes it a little awkward to hold, it also protrudues about 2mm too far to line up with the little stand so the phone wobbles while typing or touching the screen. It's an improvement on just the camera stand which makes the phone fall over when you touch the screen. You could probably file the edge of the belt clip to a little flat angle and make it into a very good stand.
The belt clip supplied with the case is incompatible with the windscreen mount. The windscreen mount comes with a special octagonal one. I'm guessing this is to hold the phone stably. It seems to hold it fairly well though I have not tried it in a car yet.
Digression but today I also had a decent car audio install done, and sadly it's shown up just how crap the analogue output on the N900 is. I'm going to stick to burning MP3 CDs until I get some head unit that can use USB mass storage.
With careful positioning of the windscreen mount it may well be possible to use this for recording video while driving, you have to bend it to the extreme right of the phone though, at which point it may not be stable enough for filming. If you can handle having the suction cup in view on the edge of the screen, filming should be fine. Just need an app now that does a continuous loop style recording, discarding footage over 10 minutes old and providing a "that **** just pulled in front of me and slammed on the brakes" button to archive the footage to a safe location.
I took some pictures, please excuse the poor quality but I was using the works Nokia 6303 which has a terrible camera.
