I just went the model up and got RE050As
Good choice
Keep an eye on your tyres/tracking from now on - replacing 2 x RE050A's doesn't come cheap!
They are the same though aren't they? It's just a name change difference, M-Sport was used for pre-facelift and Sport was used for facelift. Or that's my understanding anyway.Can.. worms.. everywhere![]()
I think it was known as sport until around 2005 when they changed the name to msport?
there were some minor spec changes i believe, like leather steering wheels as standard or whatever.
But nothing major.
[TW]Fox;16672992 said:Unless Sytner are doing a special offer you would be mad to get your MOT done there.
BMW also wont do 'tracking' they'll do a KDS Alignment at a cost of at least £200.
£99 for front brake pads inc fitting sounds expensive to me!.
EBC original quality pad:
£56.80
Brake pad sensor cable:
£12.93
Fitting by any local indy/garage:
£10-20 max
Those prices were just pulled off Google, I'm sure you can find them even cheaper. My sensor leads were £5 for example and were genuine BMW ones.
