Also because the rear tyres are wider![]()
The thing is as my weekends are full I only have time during the week and I'm having to take an hour out of work to drop the car off tomorrow, if I had to take another hour out of work for a second seperate "appointment" it would negate the 25-30 odd quid I'd save from taking it to an indie.[TW]Fox;16673088 said:Just get it MOT'd at a local place for 25 quid and let Sytner do the brakes.
Yeah I'm sure sourcing the parts seperately and getting and indie to fit them would work out a little bit cheaper but I don't have the time as I need my car in working condition this weekend and I don't want to risk running it around on low pads and damaging the discsThose prices were just pulled off Google, I'm sure you can find them even cheaper. My sensor leads were £5 for example and were genuine BMW ones.
*snip*
Your pressures are high, 41psi is abit high for a BMW thats not fully loaded or driven on track, drop them a little and experiment.
Tyres pressure can heavily effect how a car handles and tyre wear.
In an M3 you always want higher pressure in the rear, try between 36psi-38psi. In the front try 32-34psi. I'd go with 34/36 personally, but as a bit more extreme maybe try 32/38 and just go with what feels best to you. The reason the pressure is higher in the rear due to it been RWD, you want the car to rotate from the rear, essentially reducing understeer.
As mentioned get the car hunter alligned but by a specialist who knows about car geo/allignments. You high speed unstability is no doubt due to excessive toe out settings.
Toe out gives much sharper/quicker turn in reducing understeer unless you go too extreme but it can make a car feel unstable at speed.
Cars from the factory will normally have slight toe in for stability, people tend to add toe out to sharpen up the car. Then you have castor and camber, but take the car to a specialist, tell them how you want it to feel and they will set the car up for you and well then give it a test drive and well adjust.
My manual says to run the rears at 41psi and fronts at 35ish iirc. Why do you suggest differently?
Good choice
Keep an eye on your tyres/tracking from now on - replacing 2 x RE050A's doesn't come cheap!
Eagle F1 asymetrics were so much better
My E46 manual said 35 front 42 rear. When loaded this increased to, IIRC, 42 front and 49 PSI at the rear. I've run the rears at 49 before, after loading the car up with 4 people and a boot full of luggage before driving a long journey. Was a tad worrying doing it while staring at "51 PSI MAX" written on the side of the wheel.[TW]Fox;16674462 said:Thats interesting, because my manual recommends 39PSI at the back.
Bad choice, these were on my subaru when i got it and once i had used them up i couldent change them quick enoughEagle F1 asymetrics were so much better
If by better you mean by turning into cheese then yes.![]()
)The ultra sessanta's are great, i have not had them before but have reccomended them to a few friends. One of them has them on his 300 bhp Focus RS and alltho there soft and dont last long there great. I just see them as another F1![]()
I would imagine the tyre manufacturers have factored in the effects of running at e.g. 51 PSI at the maximum load rating at the maximum speed rating i.e. the equivalent of over-inflating an E46 330i's rear tyres by 2 PSI, loading the car with 425 KG (equal to three 20 stone blokes and a 20 stone driver) and, considering the 330i requires W, Y or ZR tyres, at least "over 150 MPH" or maybe up to 169 MPH or 186 MPH!To those putting 49psi into a tyre that has a maximum rating of 51psi seems dangerous.
