lol neodude
Maybe you can tell me what happens when you cut a sandwich in half?
ROFLMAO!
lol neodude
lol neodude
If the treadmill could keep matching the wheel speed infinately the plane wouldn't take off
Yes.It.Would.
Wheel speed has no bearing at all on whether a plane could take off. You have planes with skies instead of wheels, or floats (in case of sea planes).
All thrust is from the jet engines attached to the wings, the wheels simply stop it from scraping its belly along the run way.
If the plane was scraping along on its belly at the same speed of the treadmill it still wouldn't take off.
I don't care if it's on wheels, ice skates or a skateboard, if the speed of the plane is equal to that of the treadmill the plane will be static, if it's static it can't take off.
You are totally missing the point. The plane does move forward with enough speed to gain lift and fly. The treadmill simply spins the wheels, it is the jet engine moving the plane forward.
If your moving forward on something that is moving backwards at the same speed as your forward movement you stay still regardless of your source of power or how the force is moving you forward.
You have around 200,000 lb of thrust pushing a 777 forward...for it to stand still you would have to have the same force in the opposite direction.
If you think the plane won't be moving then what, praytell, is this mysterious -200,000 lb force?
The treadmill is irrelevant. The plane only needs relative motion between it and the surrounding air.
I understand completely what you are saying, but for the plane to attain a speed where it can take off the wheels need to spin faster than the treadmill / the plane needs to move faster than the treadmill.
It's a completely hypothetical situation but it would be impossible to convert the forward thrust from the jet engine into forward movement WITHOUT the wheels moving faster than the treadmill, as the wheels are the only point of contact.
How would it create the wind resistance / lift without physically moving through the air?
