Dell Studio 540 Display going blank
21 Feb 2006
Evening all,
A friend of mine has a Dell Studio 540 which is about 18 months or so old. Recently after 30mins or so of gaming the screen would go blank for a minute or so, then come back for a couple of mins, then go off again, etc etc. Apparently its now doing this after even shorter time.
It came with a 9800GT graphics card, and my first thought is that this was overheating, however checking with GPU-Z it didn't go over 75 degrees after an hour of gaming, and also checking the CPU with RealTemp that didn't go over 65 degrees.
I am still convinced its a graphics card problem though. The next step it seems like would be to get a new card. Then there is the next problem of finding a card which will work ok with the current PSU, which is believe is 350w, with one 6pin power for the GFX card. Its enough to run a 9800GT as standard so what would be the best card to get to suit these power requirements? I was hoping for 5770 but that may be a bit too much?
Any help is much appreciated!
Have you tried hooking the monitor up to another source (other PC, laptop, games console, DVD/blu ray player) and see if it exhibits the same problem?
Alternatively, do you have a known working monitor that you can hook up to your Dell. If that works fine - its a monitor issue, if it shows the same problems then it is most likely the 9800GT.
Also, do you have a PCI graphics card you can borrow for a short time to check if the 9800GT is at fault?
Edit: sorry, meant PCIe above, but if you have any PCI cards kicking about - they should work fine for diagnostic purposes.
Yep its been tried on another monitor and a TV too, same problem.
Good idea, I have an old 7800GT SLi rig which my parents have inherited, I'm sure they won't miss one of them!
have you tried both of the video outputs on the 9800gt? if its just one of the outputs gone dodgy, then just use the other one - saves monies :)
