Catalyst 10.6_Win7_Vista preview..exe
Sexy time! Thanks :D
EDIT - You running these with you 5770 Crossfire? I'm still on 10.4s for my 5770 CF.
just check my update guys as just read some are reporting a fake driver
I've not tried it as I carn't get to download, all i get is this, The file you are trying to access is temporarily unavailable.
Couldn't read that text you have to put in so i refreshed and now keep getting the above:(
TaKeN, I'm on 10.4b and so far so good in BFBC2
The ATI_Catalyst_10.5_Hotfix driver is the best i have used for Battlefield BC2, ( loads maps in 4 secs ) I would need to see good reviews of newer drivers now for me to change. Will download ready though just in case !! - Thanx
Downloaded and installed fine here, BUT, BSOD on restart and every boot since.
Wont unistall in safe mode and roll back through system install fails also.
I had to install the older 10.4s over the top to get the machine stable again :S
Haven't seen anyone else have that problem TB but glad you said you did, was going to try this out tonight but think i will pass now!
I tried installing these last night. PC blue screened during installation then Windows wouldn't boot. Had to so a system restore to get my PC to boot properly. Use at your own risk.
Running fine on my crossfired 5770's did those having problems get them from ravens guru3d link?
Heres the driver info i have
Driver Packaging Version 8.74-100517a-100911E-ATI
Catalyst™ Version 10.6
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1038
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 8.14.10.0761
OpenGL Version 6.14.10.9896
Catalyst™ Control Center Version 2010.0527.1501.25109
I installed straight over the top so i think i have a different CCC version.
